查看: 3952|回复: 12
这位置是玩啥的,没看懂
发表于 2018-1-20 10:00:20 | 显示全部楼层 |阅读模式
我看到一个位置,怪怪的。看着前面要求是与电机,变压器发电机相关的。可后面的玩意怎么画风突然变化,要求懂流体分析???求指点。Primary Responsibilities:
· Works under the supervision of a Lead engineer.
· Prepare and deliver project drawings, bills of material, requisitions and other project deliverables to the project lead engineer on schedule and within budget.
· Establish control system configuration scheme according to the process design specification and customer specification.
· Prepare piping and instrumentation diagrams in cooperation with process engineer.
· Responsible for detailed instrumentation design according to the established control scheme, including the detailed design of the creation of process control logic diagram, control system interconnection wiring diagrams, IO list design, instrument list, instrument datasheet prepare, instrument hook up drawing, control system functional description, E&IC local instrument and LCP location drawing, control room layout, control cabling And so on…design. Provide technical specifications DCS/PLC and instrumentation products; provide technical evaluation of the corresponding products from the vendor.
· Check and review design documents from supplier.
· Establish power supply scheme according to the process design, make single line diagrams, electrical load list base on system and equipment information.
· Prepare electrical system specification of MV motors, LV motors, general electrical specification for mechanical package. Prepare the material requisition of the MV/LV equipment, SWGR, transformer and so on.
· Cooperate with mechanical discipline on vendors’ technical documents, guide the supplier to comply with Alstom design standard. Check and review the design documents from supplier, control the quality and documents delivery schedule.
· Responsible for detailed electrical design according to the established power supply scheme including the detailed design of power supply system, single line diagram design, electrical load calculation, design primary and secondary schematic diagrams for sub-supplier, review the detailed drawing of supplier, design cable routing, cable conduit design, cable tray design, power cable connection diagrams, control cable wiring diagrams for electrical devices and instruments. Electrical room layout.
· Provide bid evaluation sheet, cooperate with sourcing to evaluate the technical issue of the product.
· Support site commissioning, training, operation and maintenance manual, etc. in cooperation with process engineer for the project being constructed according to the contract
· Other task assigned by Discipline Manager.
Qualifications Required:
· PI&D reading and drafting experience
· Knowledge and experience in instrumentation selection, application, PLC/DCS control system design, electrical equipment and related site installation.
· Knowledgeable in gas analyzer, fluid analysis instrument.
· Familiar with control system programming in PLC and DCS. At least be experienced in Siemens, AB PLC system and Emerson, Foxboro, ABB’s DCS system.
· >1 years Control system commissioning experience
· Bachelor degree in Electrical/Automation Engineering required
· Minimum >3 years experiences after BS
· Strong experience and technical background for EI&C engineering design
· Good English communication skill
· Can accept at least 30% overseas travel
Desired
· Familiar with electrical design standard in IEC, SAMA, BS, EN, ANSI, ASME and other internal standards.
· Experience in power plant design or FGD system design
· Experience in digital system
· Skill in Comos, Autocad.
做从未做过的事情,做一个酷炫的仔
发表于 2018-1-20 11:02:14 | 显示全部楼层
Flue-gas desulfurization (FGD) 烟道气脱硫处理,应该是化工环保行业,还有工厂供电设计。
原来如此,完全是我不懂的行业  发表于 2018-1-20 11:17
MV/LV equipment 中/低压 设备, SWGR(swichgear)电力开关装置,和断路器类似,不过电压电流更高,用油、真空或六氟化硫作隔断媒介。  发表于 2018-1-20 11:17
发表于 2018-1-20 11:05:45 | 显示全部楼层
fluid analysis instrument   流体分析仪器
发表于 2018-1-20 11:54:13 | 显示全部楼层
这个职位要求一个全能型的人才
发表于 2018-1-20 13:53:08 | 显示全部楼层
就是项目管理公司,要求知道的多,有机会可以去,
八爷,一般项目管理公司是啥意思,怎么个玩法  发表于 2018-1-20 20:46
发表于 2018-1-20 14:34:15 | 显示全部楼层
要求这么多,银子肯定不少
发表于 2018-1-20 20:25:29 | 显示全部楼层
这感觉就是将电气跟仪控俩岗位的要求捏一块了。
电气:PC/MCC,选变压器,UPS,变频器,选/布柜子,一/二次接线,拖设备,照明;
仪控:选过程仪表(温度/压力/流量/密度...),控制阀门,仪表接线,PLC/DCS,工程师/操作员站;
输入:
工艺专业提供P&ID和工艺设备/管道布置图;动/静设备专业提供动/静设备负荷/控制资料;土建提供暖通设备/管道布置图;
输出:电气设备/柜子/电缆桥架选型,供应商技术资料审查,电气设备布置图,桥架电缆布置(给土建),询价文件(给采购),仪表/阀门选型,配管,仪控压缩空气要求(返给工艺),PLC/DCS系统,工程师/操作员站,系统调试。
所以读懂仪表流程图和工艺设备布置图,是最基本的要求,低端的要求CAD,有钱的主儿可能要求INTOOLS,PRODOK。
按业主阔绰水平和公司土豪程度,假如能选能源,就不选化工,环境的就算了,市政/基建都比它好;无尽的低价投标方案就能耗光你的热情;施工再烂点,调试消缺又要折磨你;造价水平再差点,项目干完最后亏钱,想犒劳你老板都没钱,哭死你。
仪控的还能跟工艺战几个回合,电气永远都是配角。但假如发配海外,国内企业好像还不能带家属,至亲不能相聚,背后烂事那也是一大堆,所去之地也是尽皆蛮荒,上不去最终还是得跑路,所以一开始就要想清楚了。
仪控的还能跟工艺战几个回合,电气永远都是配角 大侠,你指的工艺是哪一块,谢谢  发表于 2018-1-22 12:46
运动控制VS过程控制,以后也许有选择,也许就没有,取决于一众的对手。但特赚钱的差事,一般都不容易。  发表于 2018-1-21 01:09
这样啊,还是找位置玩我的控制模型吧  发表于 2018-1-20 22:23
GMT+8, 2026-10-23 18:25 , Processed in 0.060558 second(s), 22 queries , Gzip On.
