查看: 2368|回复: 0
SolidWorks PCB之引脚名字添加上划线
发表于 2018-2-23 08:02:48 | 显示全部楼层 |阅读模式
An overline in digital logic is used to indicate an inversion or NOT function. SOLIDWORKS PCB allows for overlines to be inserted in most text fields. A common application for inserting a PCB overline is to distinguish a pin as being an active-low signal in an integrated circuit or microcontroller. Careful consideration should be given when wiring active-low signals as they must be pulled to a low voltage to be activated.
When creating symbols in SOLIDWORKS PCB, an overline can be added to respective active-low pins. To add a PCB overline in a text field, each letter must be followed by a backslash. For example, an overline can be added to a reset pin as follows
GMT+8, 2026-10-23 13:16 , Processed in 0.074388 second(s), 21 queries , Gzip On.
