查看: 6075|回复: 23
发两个米国的招聘给大家看看行情
发表于 2018-6-25 13:22:15 | 显示全部楼层 |阅读模式
如题。有一定的参考,也有一定的笑料。
第一个:
Product Development Engineer
[size=14.6667px]HTI Technology & Industries, Inc. - Nashville, TN
[size=14.6667px]$95,000 - $115,000 a year
[size=13.3333px]
ESSENTIAL DUTIES AND RESPONSIBILITIES
  • Design electro-mechanical assemblies for home appliances and other products
  • Design injection molded parts, sheet metal stampings, aluminum die castings, cold headed parts, powder metal parts, small gears, screw machine parts, solenoid coils, electrical contacts, electrical connectors, and other component types
  • Use SolidWorks 3D CAD software to create 3D models, assemblies, and 2D drawings
  • Perform tolerance studies for assemblies and apply GD&T to drawings
  • Use SolidWorks analytical tools to predict soundness of designs
  • Create Gantt charts for assigned projects
  • Use project management tools to manage and document the design process
  • Work in a team environment to review designs with colleagues and to glean ideas for design improvements
  • Collaborate with engineering colleagues in China to effectively communicate design intent and to adapt designs to current and future manufacturing capabilities
  • Perform DOE (design of experiments) for problem solving
  • Perform FMEA (failure mode and effects analysis) for designs
  • Hands-on participation in prototype assembly and evaluation
  • Competitive product evaluations including analysis, testing, and cost estimating
  • Design test fixtures and test setups
  • Work with compliance agencies, such as UL, for component approvals
  • Assist lab technicians with data compiling and reporting
  • Provide technical support to sales and other areas of the business
  • Compile costs and assist in the internal quoting process
  • Work closely with customer’s engineers to ensure the project acceptance criteria / specifications are defined and clearly understood.
  • Work closely with customer’s engineers to review design proposal and ensure they meet customer expectations.
  • Interface with customer portals to respond to requests for changes, approvals, etc.
  • Occasional travel, (1-3 trips per year), to China to support product implementation
  • Interface with customer’s MDB (model-based definition) protocol
  • Other duties as assigned
QUALIFICATION REQUIREMENTS:
To perform this job successfully, an individual must be able to perform each essential duty satisfactorily. The requirements listed below are representative of the knowledge, skill, and/or ability required.
EDUCATION and EXPERIENCE:
  • Must have a four-year BSME or BSMET or Mechatronics degree from an accredited university or institution; or equivalent experience in product development
  • Must have 3-8 years’ experience developing electro-mechanical components or products
  • Must be a proven self-starter with intuition for what needs to be done
  • Must have good understanding of metal and plastic materials and their applications
  • Must have a strong mechanical aptitude
  • Must have a good understanding of motor technology, circuit logic, solenoids, and other electrical components
  • Must be proficient in MS Outlook, Word, and Excel software (or equivalent)
  • Must have a minimum of 3000 hours of 3D CAD design experience; preferably SolidWorks
  • Ideally know how to use a caliper, micrometer, and other measurement tools
  • Ideally have some experience with data acquisition software
  • Ideally have some experience with metal fabrication; sheet metal, welding, lathe work; etc.
LANGUAGE SKILLS and COMMUNICATION SKILLS:
  • Must have good oral communication skills in English
  • Must be able to read and write in English at a professional level
  • Ideally have foreign language skills (Chinese or Spanish are a plus)
REASONING ABILITY:
  • Must have basic problem-solving skills
  • Must be able to interact with colleagues to solve problems
  • Must be able to look for ways to make all processes more efficient
OTHER SKILLS and ABILITIES:
  • Must be hands-on with tools and equipment
  • Must know and follow safe practices when using electrical power
  • Must know and follow safe practices when interfacing with electrical and/or mechanical components, mechanisms, and other equipment
  • Must have good organizational skills in documentation and file management
  • Must be willing to follow company procedures
OTHER REQUIREMENTS:
  • Must be flexible with working hours; including nights or weekends if needed
  • Must be able to lift 50 pounds in a lab environment
  • Must have a valid driver's license
  • Infrequent domestic and international travel is required
Job Type: Full-time
Salary: $95,000.00 to $115,000.00 /year
Experience:
  • 3D CAD design: 1 year
  • electro-mechanical component or product design: 4 years
Education:
  • Bachelor's
  • Nashville, TN
Language:
  • Spanish and/or Chinese
Required work authorization:
  • United States
第二个:
Rotary Steering Senior Engineer
[size=14.6667px]SINOPEC Research Institute of Petroleum Engineering - Houston, TX
[size=14.6667px]
SINOPEC Research Institute of Petroleum Engineering (abbreviated as SRIPE) is founded on June 26, 2009. It is one of the important brainpower of SINOPEC, the R & D center of high and new petroleum engineering techniques as well as the technical support center of SINOPEC petroleum engineering at home and abroad.
SRIPE is engaged in the development planning, scientific project research, products’ R & D and technology application for petroleum drilling, completion, well logging, mud logging, well testing, reservoir stimulation and offshore petroleum engineering.
At present, there are 530+ employees of SRIPE, including 380+ employees working in Beijing, 84% of the employee have master or doctor degrees and 50%+ are senior engineers. The institute has been equipped with leading petroleum engineering labs and manufacturing and pilot testing factory. The institute focus on Solve the petroleum engineering problems by technology research and technological innovation, aiming to become a petroleum engineering institute which has its own characteristics, strong ability to innovate and international competitiveness.
POSITION: Rotary Steering Senior Engineer
Responsible for producing oil & gas downhole drilling tools, working for SRIPE in Beijing, China. The candidate should have senior level project management experience, as well as competence for rotary steering system (RSS) design, mechanical design, material properties analysis, and product performance analysis. The RSS engineer’s activities will include RSS development from prototype and testing through production, and potentially commercialization into sustaining. Candidate should interface with vendors regularly and work independently.
PLACE: Beijing, China or Houston, US
MAIN RESPONSIBILITIES:
  • Responsible for R&D of the rotary steering system (RSS) and related products.
  • Plans and conducts research into designing and developing the RSS.
  • Plans and conducts research into RSS High-Speed Motor design and optimization.
  • Works in designing and optimization of HPHT sensor and hardware circuit.
  • Experience with downhole power management and data storage technology.
  • Experience with downhole wireless communication technology research and development.
  • Plans and conducts R&D on high-speed turbine and other similar transmission devices.
  • Works in designing for high speed HPHT MWD system or rotary valve structure and performs dynamic mechanical analysis of them.
  • Works in data compression and channel transmission.
REQUIRED KNOWLEDGE, SKILLS, and ABILITIES:
  • Senior level experience as a research project manager, PMP Certification is required.
  • Must be able to work independently and lead by example.
  • Must have strong mechanical / electro-mechanical skills in RRS design.
  • Should have expert level skills with design software including any of the following: AutoCAD, Pro-E, SolidWorks
  • Should have expert level skills with FEA (Finite Element Analysis) software including any of following: ANSYS, COMSOL Multi-physics. Ability to perform stress analysis and mechanical strength analysis for downhole drilling tools.
  • Should have working experience in high-precision mechanical processing.
  • Experience with precise apparatus testing, measurement, calibration, certifying and QC.
  • Must have working knowledge of mechanical drawings, materials, and hydraulic parts.
  • Familiarity with mechanical operation, welding, sheet metal and assembling.
  • Good communication and team work skills are required.
  • Master in Mechanical Engineering from an accredited university is required, PhD is preferred.
  • 5+ years’ experience working in downhole drilling tools design and development.
  • Minimum of 10 year’s experience working in an electromechanical engineering environment.
  • Expert level skills with FEA (Finite Element Analysis) software including any of following: ANSYS, COMSOL Multiphysics.
  • PMP Certification is required.
Job Type: Full-time
点评:鬼子招的是干活的人,SINOPEC招的是救命稻草。哈哈!
发表于 2018-6-25 13:37:32 | 显示全部楼层
0侠,这什么时间的,中石化怎么还在招旋转导向,现在玩这个已经晚了
就是最近的。哈哈  发表于 2018-6-25 13:57
发表于 2018-6-25 13:38:07 | 显示全部楼层
读个mba翻上管理层~好多三哥都是那样
发表于 2018-6-25 14:09:04 | 显示全部楼层
11111111111
发表于 2018-6-25 15:34:02 | 显示全部楼层
哈哈,不错,价格也合理,
有些东西现在玩,也没有什么前途了,
米国好像正在规划船气外输的一些项目,那个,也许更有前途,
8爷懂行!666  发表于 2018-6-25 20:00
发表于 2018-6-25 15:49:55 | 显示全部楼层
第一个招聘工作职责写的好细:
Must be able to lift 50 pounds in a lab environment都专门提出
难怪第二个看上去和国内招聘要求挺像,强调经验。
发表于 2018-6-25 16:21:02 | 显示全部楼层
这钱是到手的,还是没扣税的?
有奥巴马医保。。。要被特朗普取消咯。。。哈哈  发表于 2018-6-25 21:56
老美这么相信广大人民群众,老美是不是也要自己交纳类似我们社保一样的保险啊?  发表于 2018-6-25 17:50
米国的税,都是自己报的,米国不存在‘睡前收入,睡后收入’  发表于 2018-6-25 16:31
7万
发表于 2018-6-25 17:28:45 | 显示全部楼层
由于sales 方面的职位......
感激涕零。  发表于 2018-6-25 20:03
我单独给你找找,猫  发表于 2018-6-25 20:01
发表于 2018-6-25 19:38:02 | 显示全部楼层
好多看不懂,尴尬了。好歹当年也是一次过46的
6级都过了,神人, 当年死皮赖脸才过4  发表于 2018-6-25 23:09
发表于 2018-6-25 22:45:46 | 显示全部楼层
用的是design,不是to design也不是动名词,学习了
GMT+8, 2026-10-23 20:29 , Processed in 0.127702 second(s), 22 queries , Gzip On.
