查看: 4200|回复: 37
每日一段伯德桑
发表于 2018-10-10 22:15:16 | 显示全部楼层 |阅读模式
Start with simple in which states concept and procedure about design
Dimension and Tolerance
Part of a machine designer's task is to specify the parts and component necessary for  a machine to perform its desired function.
Early in the design process ,it's usually sufficient to work with nominal dimension to determine function ,stress ,deflection,and the like.
However ,eventually it is necessary to get to the point of specificity that every component can be reach and every part can be manufactured.
For a part to be manufactured , its essential shape ,dimensions ,and tolerance must be communicated to the manufacturer.
That's usually done by means of a machine drawing ,which may either be multiview drawing on paper or digital data from a CAD files.
Either way ,the drawing usually represents a legal document like a code between the parties invovled in the design and manufacture of the part.
It is essential that the part be defined precisely and completely so that it can only be interpreted in one way.
The designer's intent must be conveyed in such a way that any manufacturer can make the part or component to satisfication to any inspector.
Terms ,Nominal size ,Limits ,Tolerance ,Bilateral tolerance ,unilateral tolerance ,clearance ,interference ,allowance ,fit ,GD&T.
Any part  need to be more explain ?
一剑X心 + 3 bird song!
发表于 2018-10-10 22:57:48 | 显示全部楼层
已经很流畅了,哈哈,到这水平,有饭碗了,
我因为没有英文教育,说能到这样,纯写,写不到这个程度,阿拉自己揭露老底了,哈哈,
不听,不知道iPhoneX怎么念,机械方面,也有很多念法从字面上看不出来的。  发表于 2018-10-11 18:16
further explanation  发表于 2018-10-11 09:54
Do you need more explanation?  发表于 2018-10-11 09:53
Do you need more explanation?  发表于 2018-10-11 09:51
最后一句是不是应该用 explained?  发表于 2018-10-11 08:31
回复 支持 1 反对 1
发表于 2018-10-10 23:32:31 | 显示全部楼层
看的什么书?
我现在看的是dimensional variation management handbook和design dimensioning and tolerancing.
回复 支持 2 反对 0
发表于 2018-10-10 22:20:33 | 显示全部楼层
一看就是你自己写的。
英语不行,还得练。
不是习惯不习惯,,根本就是错的,,还有什么my mistaken,,高中生都该知道不能这么说。呵呵。  发表于 2018-10-11 08:52
看得出他是自己学英语的,没经常和老外交流,老外习惯不这么用  发表于 2018-10-11 08:39
should say incorrect you moron  发表于 2018-10-11 07:23
Obviously  发表于 2018-10-10 22:44
第一句和最后一句也是?  发表于 2018-10-10 22:36
发表于 2018-10-10 23:33:34 | 显示全部楼层
听力的话,了解一下逆向听写法,要点是零错误,耳朵熟悉了,就跟听本地方言一个道理。
行文书写,建议还是对比汉译的规范或者产品说明书,安装手册等,因为涉及到法律法规,责任承担的问题,一般用词都非常严谨,小心。
我比较烦正式文件中出现口语,英语也就罢了,汉语的东西中出现“板子”,柱子“,”“螺丝”,“螺帽”,“管子”,“角铁”,实在是很倒胃口。
米叔偶像  发表于 2018-10-11 11:08
英文书写字,与口语差异比中文还大,中文经历白话运动,英语没有,书写就是书写  发表于 2018-10-10 23:55
米莎熊  发表于 2018-10-10 23:39
发表于 2018-10-11 17:37:39 | 显示全部楼层
语言主要是刺激大脑皮层的时间问题,刺激时间长,才有反应,单靠聪明才智没啥用的,
GMT+8, 2026-10-23 13:30 , Processed in 0.062213 second(s), 23 queries , Gzip On.
