查看: 2737|回复: 1
SolidWorks 2019 SP0 安装包 没和谐的
发表于 2018-10-20 10:14:31 | 显示全部楼层 |阅读模式
从和谐原理上看,如果使用SolidWorks2018的和谐大法的序列号,而不crack,那应该是30天试用版,那么灵感来了,能否修改系统日期,使其永远钉在30天呢。目前有三种手段可以做到
1硬盘还原卡能做到重启后系统日期不变
2 还原精灵能做到重启后系统日期不变
3 在虚拟机里安装
目前已经有真爱粉在测试第三种方法的可行性
im creating and testing a VMWare image of windows 10 pro x64 with MS Office 2013 and SolidWorks 2019 installed.
I found online that the following lines have to be added to the .vmx file (using notepad)
the rtc.startTime is the date/time that you want the VMWare OS to boot into, its in UTC format (use https://www.mbari.org/utc-calculator/ to calculate your required date) the rest of the lines are for turning off the time sync between host and guest OS.
rtc.startTime = "1543569600"
tools.syncTime = "FALSE"
time.synchronize.continue = "FALSE"
time.synchronize.restore = "FALSE"
time.synchronize.resume.disk = "FALSE"
time.synchronize.shrink = "FALSE"
time.synchronize.tools.startup = "FALSE"
time.synchronize.tools.enable = "FALSE"
time.synchronize.resume.host = "FALSE"
time.synchronize.resume.memory = "FALSE"
虚拟机使用win10安装solidworks2019,30天试用版
青画 + 3 板叔稳
 楼主| 发表于 2018-10-20 10:37:43 | 显示全部楼层
SSQ在发布DATAKIT 2018.4 Import-Export Plugins for SolidWorks2010-2019 Win64插件种子文件时
截图呈现这一幕
难道SSQ购买了正版SolidWorks2019 SP0 顶级版参与测试盗版的插件吗,亦或是也采取了锁定系统日期来使用SolidWorks2019 SP0 顶级版。
GMT+8, 2026-10-23 14:28 , Processed in 0.097027 second(s), 22 queries , Gzip On.
