查看: 21372|回复: 4
solidworks2017SP2更新和solidworks2016SP5更新
发表于 2017-2-17 18:23:20 | 显示全部楼层 |阅读模式
北京时间2017年2月14日发布,修补列表
446529
SOLIDWORKS PDM - Workflows: Foreign Language General: A condition set up with a Variablename in SOLIDWORKS PDM workflow properties will not save the selected 'Yes' argument.
SOLIDWORKS PDM
605900
SOLIDWORKS PDM - Search Performance: Variable search takes much longer (minutes vs seconds) when 'display folders' is checked than when it is not checked (vault specific)
SOLIDWORKS PDM
626567
SOLIDWORKS Simulation - Contact Set: When defining a Virtual Wall, selecting the face of a Beam doesn't trigger the 'Invalid entity on beam body was selected' error message
652300
Drawing Views - Broken Views, Dimension:Radial dimensions attached to spherical silhouette edges disappear if center of radius is inside break view.
SOLIDWORKS
668886
Translator - IGES: Direction of 3D-sketch changes in the IGES file which specified and outputted 'Output coordinate system'.
SOLIDWORKS
671348
SOLIDWORKS PDM Bill of Materials (BOM): BOM QTY for sub assembly part is different when using 'reference count' and 'reference count (BOM QTY disregard)' when BOM QTY not used
SOLIDWORKS PDM
680562
SOLIDWORKS Simulation - Static Postprocessing: Enhancement: Simplify shear stress direction convention used in SOLIDWORKS Simulation.
751135
SOLIDWORKS Electrical - 3D Routing, Wiring: Error when using the Flatten Route dialog> Select Annotation and Display 3D connectors - > OK.
SOLIDWORKS Routing
760386
Sheet Metal Features: Swept flange feature flat pattern length is wrong in the included part when using K-factor.
SOLIDWORKS
762591
Drawing Views General, Feature - Multi-Body: Selected bodies defined in relative view are not retained when the view's reference configuration is changed; all bodies are shown.
SOLIDWORKS
772979
Toolbox - Customize, Physical Materials: First material of the list gets applied, if any single material is enabled in custom property that is linked to material database.
SOLIDWORKS
817572
SOLIDWORKS PDM - Preview Foreign Language - Chinese Simplified: Preview the Office files will get the messy code for Chinese Simplified characters.
SOLIDWORKS PDM
844172
SOLIDWORKS PDM - Cold Storage: Cold Storage Schema start (CS_BeginOperation) can at times cause 100% SQL CPU for hours in replicated vaults *vault specific*
SOLIDWORKS PDM
863764
Parts, Feature - Pattern Sheet Metal Features: Message 'The edge, axis, or dimension used to define this pattern is no longer in the model' observed after rebuilding this part.
SOLIDWORKS
880224
Translator - ProE In: Enhancement: Support the import of Creo 3.0 part and assembly files.
SOLIDWORKS
881861
SOLIDWORKS Electrical -3D, API: Create 2D drawing - Create Marks - Components mark are not created for the parts used under the 1st level assembly.
884321
SOLIDWORKS Electrical - PLCs, Connectors: Enhancement: Ability to use multiple attribute and line return “|” with PLC Input/Output description attribute “#P_TAG_N” and other PLC attributes.
933190
SOLIDWORKS PDM - Cards: Updating version free variable on checked in PDF fails with 'Could not save card data to file since the file is opened in another application'
SOLIDWORKS PDM
940857
SOLIDWORKS - Installation: Error 27504 'SQL version requirements not met' when installing Database Server Service via MSI and connecting to SQL Server having a Cumulative Update (CU)
SOLIDWORKS PDM
953341
SOLIDWORKS Electrical - 3D Routing, Wiring: Routing results inconsistent across service packs.
955005
Property Tab Builder: Property Tab Builder launches multiple instances of Excel.exe
SOLIDWORKS
960185
SOLIDWORKS Inspection - Export and Publish: Addin - Some values extracted in this drawing are different from the dimension values on the drawing.
964037
DXF/DWG Translator - PDF Out: Crash when using 'save as' on a drawing to a PDF, JPEG file on Windows 7 OS
SOLIDWORKS
965507
SOLIDWORKS Electrical - Schematic: Unable to delete symbol circuits - project specific
965935
Drawings - Bill of Material (BOM) Tables: If you add a new row on a BOM and try to add ‘Part Number’ manually; SOLIDWORKS will not save the value.
SOLIDWORKS
970894
SOLIDWORKS Inspection - Misc: 'There has been an unhandled error in the software' on capturing dimension.
976242
SOLIDWORKS API - OLE: Editing Excel OLE object in SOLIDWORKS drawing; shows different behavior in 2016 than 2015.
SOLIDWORKS API
985698
SOLIDWORKS Electrical - General: Enhancement: Ability to define terminal mark by equipotential for a project.
985739
SOLIDWORKS PDM - Archive and DB Server: 'No credentials are available in the security package' when attaching to archive server using Windows 10 with Microsoft account after 'Sep 13 update, KB3189866'
SOLIDWORKS PDM
988611
SOLIDWORKS PDM - Cards: When using a combo box drop list that is linked to a data card list the default value from the list does not get stored.
SOLIDWORKS PDM
988617
User Interface - Customize General: Reference triad disappears from Graphics Area when selecting measure tool.
SOLIDWORKS
988642
SOLIDWORKS PDM - Archive and Database Server: 'No credentials are available in the security package' when attaching to archive server using Windows 8.1 having 'Sep 13 update, KB3187754'
SOLIDWORKS PDM
993129
Licensing - SNL: Latency issue - SOLIDWORKS 2017 products fail to check out license with “Could not obtain a license for SOLIDWORKS. Server node is down or not responding.”
SOLIDWORKS
994749
Assemblies, Mate - Standard: Errors are given after assembly is saved, reopened, rebuilt again. 'One of the entities or referenced features of this mate is suppressed, invalid, or no longer present.'
SOLIDWORKS
集成安装包,直接安装即为solidworks2017SP2,已安装solidworks2017SP2以下版本的,双击安装包中的setup.exe,即为升级安装。
链接: https://pan.baidu.com/s/1nv4ocm1  密码: 4kyx
虽有网盘,但鉴于国内个人免费网盘的前景不明,加上近期baidu网盘下载速度那是相当尴尬,所以下载到自己硬盘的东西才是最好的。
 楼主| 发表于 2017-2-17 18:32:58 | 显示全部楼层
solidworks2016SP5更新
solidworks2016SP5
链接: http://pan.baidu.com/s/1mhIhwLE 密码: u4ur
和谐补丁可使用solidworks2016SP0-SP4任何一款,同版本一般通用
2016版没集成PCB设计,需要solidworksPCB的,请到此帖
适合solidworks2015-2016的solidworks PCB 2016SP3
http://www.jixietop.cn/forum.php?mod=viewthread&tid=1487&fromuid=779
(出处: 中国机械荟萃山庄)
2016版没集成Visualize实时照片级渲染工具,有需要的
发表于 2017-2-18 11:48:28 | 显示全部楼层
sw2017,装好后用SolidWorks.2017.Activator-SSQ.exe破解不成功怎么解?
多谢  发表于 2017-2-18 13:31
因为你没按顺序破解,在安装软件前要启动补丁一次,安装后再启动补丁一次。  发表于 2017-2-18 12:17
GMT+8, 2026-10-23 10:20 , Processed in 0.520497 second(s), 22 queries , Gzip On.
