返回列表 发新帖
楼主: 2266998
追究那些存在的数据,有些是虚拟的数据,
发表于 2019-2-26 14:35:52 | 显示全部楼层
"Good resistance against corrosion by acids and oxygen makes Monel a good material for the chemical industry. Even corrosive fluorides can be handled within Monel apparatus; this was done in an extensive way in the enrichment of uranium in the Oak Ridge Gaseous Diffusion Plant. Here most of the larger diameter tubing for the uranium hexafluoride was made from Monel.Regulators for reactive cylinder gases like hydrogen chloride form another example, where PTFE is not a suitable option when high delivery pressures are required. These will sometimes include a Monel manifold and taps prior to the regulator that allow the regulator to be flushed with a dry, inert gas after use to further protect the equipment."
hao ,hah  发表于 2019-2-26 15:06
GMT+8, 2026-10-24 00:27 , Processed in 0.304250 second(s), 17 queries , Gzip On.
