查看: 2550|回复: 0
熟悉SolidWorks CAM 界面
发表于 2019-3-9 09:44:32 | 显示全部楼层 |阅读模式
The SOLIDWORKS CAM user interface closely follows the above process. These commands will be discussed in greater detail in future articles.
A Set-up options
B  Program generation commands
C  Options to add operations interactively
D   Technology Database Options
E   Options for defining features to be extracted when using (AFR)
F   CAM Feature Tree – Shows extracted features
G   CAM Operations Tree – Edit or add operations interactively
H   CAM Tool Tree – Editing current Tool Crib
SOLIDWORKS CAM Standard licenses are available to all SOLIDWORKS Subscription Service customers using SOLIDWORKS 2018 or higher.[td]
Features
SOLIDWORKS CAM
Standard
SOLIDWORKS CAM
Professional
General Features
AFR – Automatic Feature Recognition – Holes
AFR – Automatic Feature Recognition – Pockets, Boss
AFR – Automatic Feature Recognition – Turn
KBM – Knowledge Based Machining
Automatic Recognition of Multiple Setups
Indexing of the 4th & 5th axes including tombstone
Sorting of the Operations
Toolpath Simulation
Step Through Simulation
Tolerance Based Machining – C# macro
Assembly Machining
CAMWorks Configurations
Stock and Work in Process Models
Setup Sheets – XML, XMLT, MDB
e-Drawings Publisher
Universal Post Generator (UPG)
Ancillary applications installed separately
CAMWorks Library Features (supports only 2.5x features)
Import / Export of CAM data
Contain and Avoid areas and features
MES Feed Speed Library
2.5 Axis Milling Features
Interactive Feature Creation
Rough Milling
Finish (Contour) Milling
Face Milling
Thread Milling
Center Drilling
Drilling
Countersinking
Reaming
Tapping
Engraving
3 Axis Milling Features
Multi-surface feature creation
Area Clearance
Z Level
Flat Area
Contain and avoid areas and features
Turning Features
Face Rough
Face Finish
Rough Turn
Finish Turn
OD Threading
Cut-off
Groove Rough
Groove Finish
Bore Rough
Bore Finish
Center Drill – on center
Drill – on center
Tap – on center
ID Threading
Extra Features
High-Speed Machining
VoluMill
NC Editor
GMT+8, 2026-10-23 15:09 , Processed in 0.062540 second(s), 21 queries , Gzip On.
