查看: 2838|回复: 3
小霍这把椅子看起来前景不错,有大侠感兴趣的吗
发表于 2019-5-24 20:06:31 | 显示全部楼层 |阅读模式
Process Engineer, Zhangjiagang, UOP
Complete job description
The process engineer is accountable for the basic engineering design of UOP's Hydrogen and Gas Processing technologies. The engineering design work consists of the use of proprietary models and simulations to develop detailed hydrualic analyses and sizing of major equipment, including vessels and piping. Basic design engineering is done to support proposals, new equipment and revamp projects.
Accountabilities:
Run process simulation tools for design and alternate cases
Size piping and control valves and perform hydraulics
Develop project specifications including all major equipment
Perform the basic engineering design including Piping & Instrumentation Diagrams (P&ID's) for customer projects
Contribute and participate in customer meetings as assigned and agreed with the Project Manager
Apply current design practices and tools for completion of assigned tasks
Be familiar with the work process and quality policy and apply as appropriate to each project
Document all calculations and work processes in a clear, concise format
Work with equipment vendors on specifications and procurement of equipment
Adapt UOP design standards and procedures to meet project-specific requirements on assigned design tasks
Key Responsibilities
Perform laboratory testing
Adjust and calibrate instruments
Research new methods
Design experiments
Basic Qualifications:
Bachelor's Degree in Chemical Engineering, or equivalent, is required
Minimum 5 plus years operations and/or design engineering experience in the refining or petrochemical or gas industry are required
Additional Qualifications:
Experience with Refining and Petrochemicals design highly desired
Strong written, verbal and interpersonal communications skills
Ability to function well within a team based work environment
The ability to complete moderately complex to complex assignments is needed
Capable of applying a broad knowledge of principles, practices and procedures
Ability to independently carry out varied assignments that may require modification of standard procedures
Capable of working under limited to minimal supervision. Technical guidance is available for unusual or more complex problems.
Fluent in the English language
Ability to travel up to 15% annually
发表于 2019-5-24 21:07:08 | 显示全部楼层
属于高价椅子了,
发表于 2019-5-24 21:36:23 | 显示全部楼层
望小霍兴叹,,,
 楼主| 发表于 2019-5-24 22:49:18 | 显示全部楼层
可惜俺没接触过这行,要不肯定申请转过去。光看职责前两条俺就觉得值得玩。
GMT+8, 2026-10-24 01:32 , Processed in 0.089314 second(s), 20 queries , Gzip On.
