查看: 2811|回复: 6
新型储氢材料来啦,逆天黑科技呀
发表于 2019-6-19 20:31:44 | 显示全部楼层 |阅读模式
New material could unlock potential for hydrogen powered vehicle revolution
Scientists have discovered a new material that could hold the key to unlocking the potential of hydrogen powered vehicles.
Another 'green' technology with great potential is hydrogen power. However, a major obstacle has been the size, complexity, and expense of the fuel systems—until now.As the world looks towards a gradual move away from fossil fuel powered cars and trucks, greener alternative technologies are being explored, such as electric battery powered vehicles.
An international team of researchers, led by Professor David Antonelli of Lancaster University, has discovered a new material made from manganese hydride that offers a solution. The new material would be used to make molecular sieves within fuel tanks—which store the hydrogen and work alongside fuel cells in a hydrogen powered 'system'.
The material, called KMH-1 (Kubas Manganese Hydride-1), would enable the design of tanks that are far smaller, cheaper, more convenient and energy dense than existing hydrogen fuel technologies, and significantly out-perform battery-powered vehicles.
Professor Antonelli, Chair in Physical Chemistry at Lancaster University and who has been researching this area for more than 15 years, said: "The cost of manufacturing our material is so low, and the energy density it can store is so much higher than a lithium ion battery, that we could see hydrogen fuel cell systems that cost five times less than lithium ion batteries as well as providing a much longer range—potentially enabling journeys up to around four or five times longer between fill-ups."
The material takes advantage of a chemical process called Kubas binding. This process enables the storage of hydrogen by distancing the hydrogen atoms within a H2 molecule and works at room temperature. This eliminates the need to split, and bind, the bonds between atoms, processes that require high energies and extremes of temperature and need complex equipment to deliver.
The KMH-1 material also absorbs and stores any excess energy so external heat and cooling is not needed. This is crucial because it means cooling and heating equipment does not need to be used in vehicles, resulting in systems with the potential to be far more efficient than existing designs.
The sieve works by absorbing hydrogen under around 120 atmospheres of pressure, which is less than a typical scuba tank. It then releases hydrogen from the tank into the fuel cell when the pressure is released.
The researchers' experiments show that the material could enable the storage of four times as much hydrogen in the same volume as existing hydrogen fuel technologies. This is great for vehicle manufactures as it provides them with flexibility to design vehicles with increased range of up to four times, or allowing them to reducing the size of the tanks by up to a factor of four.
Although vehicles, including cars and heavy goods vehicles, are the most obvious application, the researchers believe there are many other applications for KMH-1.
"This material can also be used in portable devices such as drones or within mobile chargers so people could go on week-long camping trips without having to recharge their devices," said Professor Antonelli. "The real advantage this brings is in situations where you anticipate being off grid for long periods of time, such as long haul truck journeys, drones, and robotics. It could also be used to run a house or a remote neighbourhood off a fuel cell."
The technology has been licenced by the University of South Wales to a spin-out company part owned by Professor Antonelli, called Kubagen.
The research, which is detailed in the paper 'A Manganese Hydride Molecular Sieve for Practical Hydrogen' is being published on the cover and within the printed version of the academic journal Energy and Environmental Science.
这种新材料由兰开斯特大学David Antonelli教授带领的团队发现,由锰氢化合物制成,可以用来制造燃料罐内的分子筛。该技术据说比目前的锂电池成本低五倍,续航里程却长五倍。可以储存四倍于当前燃料电池技术所能存储的氢。
这要是能实现工业化,那英佬岂不满世界捡银子呀。说不定哪天飞机都得换这个。8爷以前提的分子筛果然出现啦。话说以后地上跑的,天上飞的,还有啥能留给我们玩的?
发表于 2019-6-19 20:52:13 | 显示全部楼层
英佬手里现在有电机,电机控制器,高速减速箱,切换离合器,还有一堆东西,蓄势待发,我们还在笑,在等弯道
盎格鲁系心里明白,没有弯道,小鼻子氢车准备好了,等海雕协调
发表于 2019-6-19 22:24:10 | 显示全部楼层
2266998 发表于 2019-6-19 20:52
英佬手里现在有电机,电机控制器,高速减速箱,切换离合器,还有一堆东西,蓄势待发,我们还在笑,在等弯道 ...
8爷,问下您指的切换离合器是哪种类型的离合器,是多片纸基摩擦片湿式离合器吗?主要功能和性能是?
以前只知道GKN做缸套和传动轴,后来才发现这家英国企业真不简单。天上飞的,地上跑的,啥都有。  发表于 2019-6-20 18:17
种类很多,英佬研究切换速度方面很成功,你可以读些资料,GKN就有,  发表于 2019-6-19 22:31
发表于 2019-6-19 23:11:04 | 显示全部楼层
怀疑燃氢涡扇都已经有了,到时候空战又是代差
感觉这个真有可能。多年前DOE就让GE研发氢涡轮了,估计只是没装在飞机上给人看而已。臭鸟拿出来让人看的向来不是最牛逼的东西。细思极恐……  发表于 2019-6-20 18:25
吃,懒,躺,睡......
GMT+8, 2026-10-24 02:31 , Processed in 0.063389 second(s), 21 queries , Gzip On.
