查看: 2581|回复: 0
PHP 7.3.7 正式发布
发表于 2019-7-7 12:54:55 | 显示全部楼层 |阅读模式
PHP 7.3.7正式发布了。PHP(PHP:Hypertext Preprocessor)是一种在电脑上执行的脚本语言,主要是用途在于处理动态网页,也包含了命令列执行接口(command line interface),或者产生图形使用者接口(GUI)程式。
版本主要还是修复 bug,改进日志如下:
04 Jul 2019, PHP 7.3.7- Core:  . Fixed bug #76980 (Interface gets skipped if autoloader throws an exception).    (Nikita)- DOM:  . Fixed bug #78025 (segfault when accessing properties of DOMDocumentType).    (cmb)- MySQLi:  . Fixed bug #77956 (When mysqli.allow_local_infile = Off, use a meaningful    error message). (Sjon Hortensius)  . Fixed bug #38546 (bindParam incorrect processing of bool types).    (camporter)- MySQLnd:  . Fixed bug #77955 (Random segmentation fault in mysqlnd from php-fpm).    (Nikita)- Opcache:  . Fixed bug #78015 (Incorrect evaluation of expressions involving partials    arrays in SCCP). (Nikita)  . Fixed bug #78106 (Path resolution fails if opcache disabled during request).    (Nikita)- OpenSSL:  . Fixed bug #78079 (openssl_encrypt_ccm.phpt fails with OpenSSL 1.1.1c).    (Jakub Zelenka)- phpdbg:  . Fixed bug #78050 (SegFault phpdbg + opcache on include file twice).    (Nikita)- Sockets:  . Fixed bug #78038 (Socket_select fails when resource array contains    references). (Nikita)- Sodium:  . Fixed bug #78114 (segfault when calling sodium_* functions from eval). (cmb)- Standard:  . Fixed bug #77135 (Extract with EXTR_SKIP should skip $this).    (Craig Duncan, Dmitry)  . Fixed bug ##77937        (preg_match failed). (cmb, Anatol)- Zip:  . Fixed bug #76345 (zip.h not found). (Michael Maroszek)下载链接:
http://php.net/distributions/php-7.3.7.tar.gz
GMT+8, 2026-10-23 16:03 , Processed in 0.064872 second(s), 20 queries , Gzip On.
