查看: 3062|回复: 0
SolidWorks的声学仿真
发表于 2017-4-13 21:39:00 | 显示全部楼层 |阅读模式
SolidWorks2017SP2带来两个更新,一个是将SOLIDWORKS 3D Interconnect由beta版变成正式版,并且是默认开启。
另一个就是SolidWorks Flowsimulation2017SP2 增加了声学仿真项目
还有,在必将到来的SolidWorks Flowsimulation2017SP3更新中
The Noise Prediction is available with SOLIDWORKS 2017 SP3. The acoustic Power Level is calculated with Proudman formulae, one of the known steady-state approach in CFD. The Proudman’s formula gives an approximate measure of the local contribution to total acoustic power per unit volume in a given turbulence field.
This can be used to estimate broadband noise generated by turbulence.
Available results include the Acoustic Power, in W/m^3 and the Acoustic Power Level, in decibel (dB).
并且已经有了实际应用
GMT+8, 2026-10-23 11:12 , Processed in 0.083957 second(s), 21 queries , Gzip On.
