查看: 2141|回复: 0
SIMIULIAworks:SolidWorks云中仿真
发表于 2020-7-10 08:14:15 | 显示全部楼层 |阅读模式
Simulation software can require powerful, costly hardware. When working remotely or sheltering in place, you may not have access to your normal desktop set-up, or have the ability to communicate with your teammates as you would at the office. What is an engineer to do? The answer is simple: use SIMIULIAworks, featuring Abaqus technology, on the 3DEXPERIENCE platform.
The 3DEXPERIENCE platform is a cloud-based platform that provides a variety of software solutions for all types of designers and engineers, as well as other stakeholders within a company. SIMULIAworks is a portfolio of connected, powerful, and collaborative simulation solutions.
SIMULIAworks allows you to get to work without any data import or export. Users can perform any structural analysis task, from simple linear analyses to the most complex non-linear analyses from any browser: no more expensive hardware required. And, because it’s on the cloud, SIMULIAworks allows users to tap into the infinite power of the cloud for faster product validation from any location, no matter where you are.
The SIMULIAworks portfolio is scalable, meaning it has multiple roles that different designers and engineers in your company can use. Structural Performance Engineer, Structural Mechanics Engineer, and more; no matter what role you choose, you have will the same user interface with everyone on your team, and the ability to run simulations and share results.
When you need to do a simulation study, you simply can have the job run on the cloud in background and work on other projects. Then, when you’re ready, you can log back into the 3DEXPERIENCE platform and review your results. You can then share those results with the rest of your team, and because they’re also using SIMULIAworks, they can use their own devices and check on your work from any location as well.
Simulation has always been the holy grail of engineering. In the early days, simulation was restricted to engineers with specific levels of education and experience. This often meant that designers would have to wait days, weeks, and sometimes months to get back simulation results for their CAD designs.
Seeing the inefficiencies of this process, SOLIDWORKS addressed many of these issues with SOLIDWORKS Simulation, which is built to validate designs in parallel with the design process. This led to CAD designers doing more simulation work on their own. For more complex simulations, they would still send models to the analyst.
The 3DEXPERIENCE WORKS portfolio of solutions enables SOLIDWORKS users to now manage even the most advanced simulations in a collaborative environment on the 3DEXPERIENCE platform. Here’s is how this workflow can work in your current SOLIDWORKS environment.
GMT+8, 2026-10-23 19:04 , Processed in 0.059788 second(s), 21 queries , Gzip On.
