查看: 2869|回复: 0
达索系统二维CAD工具DraftSight引入一个新插件
发表于 2020-7-13 08:12:26 | 显示全部楼层 |阅读模式
How do designers collaborate and manage drawings for similarly large projects? Some common questions that I’m sure you are familiar with include:
How does the team track the massive amount of data?
Where can I quickly find the one drawing I need in this ocean of drawings?
How can I tell if a set of drawings is ready for signatures, a building permit application, electric wiring, HVAC, inspection, etc.?
How can I share the drawings quickly and securely?
These challenges are beyond drafting. As you know, DraftSight is very good at drafting and has been trusted by millions of users worldwide. However, to further serve its users and respond to the needs beyond drafting, DraftSight has introduced a new role called 3DEXPERIENCE® DraftSight.
As you can see, 3DEXPERIENCE DraftSight looks very similar to DraftSight with the addition of a new task pane that interacts directly with the 3DEXPERIENCE platform inside the application. In the task pane you can search for keywords, quickly locate a drawing on the platform, check files in and out to avoid conflicting edits, save a new drawing revision, replace a local version with a platform revision, and set a drawing maturity stage so your team can learn the latest status and determine the corresponding actions.
Once a drawing is checked in to the 3DEXPERIENCE platform, you can securely share it with others. For example, from a browser you can control whether a recipient can view or edit the drawing. You can even decide whether a recipient can share it with others,  In addition, the drawing can also be shared as a link that your collaborators can access direct
Looking back, DraftSight has come a long way. Ten years ago, DraftSight embarked on a mission to empower users with professional and affordable 2D communications. It has gained the trust of millions of users.
Looking forward, now the world is more interconnected, online, complex, and collaborative. With the trust and guidance of millions of users, DraftSight is going further to serve the imperative needs for online collaboration and data management.
GMT+8, 2026-10-23 17:12 , Processed in 0.068765 second(s), 21 queries , Gzip On.
