查看: 1848|回复: 0
PartSupply助力SolidWorks用户轻松找到第三方零件提供商
发表于 2021-4-4 14:02:42 | 显示全部楼层 |阅读模式
How much time can you afford to lose when searching for standard components for reuse in your assemblies?
Let’s say that you are designing a lawnmower and you need to find a motor bracket. How will you find a standard component to reuse in your assembly? Do you search with keywords to find the part? Do you search in your in-house PDM vault? Or access an external component provider?
What if there is already a motor bracket that exactly fits your needs in your PDM vault, but you cannot find it using a traditional keyword search?
The Easy Way to Find Parts & Components
3DEXPERIENCE® Marketplace PartSupply is the most comprehensive, artificial intelligence-driven catalog of sourceable 3D components.
PartSupply Standard Components Manager
The Standard Components Manager enables you to manage your company’s catalog of components to help you build, manage, and maintain an in-house components library, thereby leveraging both internal parts and components from qualified suppliers.
Some of the benefits of this product include:
1)     Save time in the design phase by accessing parts directly from within SOLIDWORKS®.
2)     Reuse internal parts created in other projects. This will help reduce your duplicate parts and avoid introducing new duplicate parts into your company’s database.
3)     Enable product development or engineering departments to access the 3DEXPERIENCE Marketplace that contains more than 935 suppliers. You also can select the partners you have worked with previously or validate new partners for the future.
4)     Create a standard system using a combination of parts from the 3DEXPERIENCE Marketplace and from your own internal assets to give your product development or engineering departments quick and easy access to the right parts.
PartSupply Optimized Components Consumer enables you to:
  •         Search and compare parts according to their CAD geometries using 3DShape search
  •         Search results based on the geometrically most similar 3D CAD parts
  •         Reuse parts created in other projects from your internal databases and PDM systems
  •         Save time in the design phase from within SOLIDWORKS or DraftSight design environments
One-Stop-Shop
Now you can have a single source of standard parts across your organization, all accessible from your SOLIDWORKS environment. You can search by shape, perform comparisons, and bookmark your favorite parts and suppliers.
You can manage massive amounts of diverse 2D/3D CAD part data across the enterprise and reduce duplicate parts at your organization, avoiding downstream costs. Plus, these applications empower your designers and engineers to quickly find standard parts from within the company’s in-house part data library or from external suppliers—with ease.
GMT+8, 2026-10-23 16:28 , Processed in 0.078333 second(s), 21 queries , Gzip On.
