查看: 3176|回复: 2
ASTM
发表于 2021-4-4 22:46:57 | 显示全部楼层 |阅读模式
工作中遇到很多不常见的材料,俺喜欢寻根问底,最后发现几乎所有不同行业,不同功能,不同工况的材料最后都收编进入ASTM中了(军用的除外)。
A = Iron and Steel  Materials
B =  Nonferrous Metal Materials
C = Ceramic,  Concrete, and Masonry Materials
D = Miscellaneous Materials
E = Miscellaneous Subjects
F =  Materials for Specific Applications
G =  Corrosion, Deterioration, and Degradation of Materials
涵盖极其广泛,塑料,纤维,玻璃等等,上次遇到的ASTM首代就是个老虎。
光铁基材料A系列就有680个之多,比如300M就在A579里面。
ASTM  AIIMASTMPortable Document Format-Healthcare (PDF) A  Best Practices Guide
ASTM A1Standard Specification for  Carbon Steel Tee Rails
ASTM A2Standard  Specification for Carbon Steel Girder Rails of Plain, Grooved, and Guard  Types
ASTM A3Standard Specification for  Steel Joint Bars, Low, Medium, and High Carbon (Non-Heat-Treated)
ASTM A6/A6MStandard  Specification for General Requirements for Rolled Structural Steel Bars,  Plates, Shapes, and Sheet Piling
ASTM  A20/A20MStandard  Specification for General Requirements for Steel Plates for Pressure Vessels
ASTM  A27/A27MStandard  Specification for Steel Castings, Carbon, for General Application
ASTM A29/A29MStandard Specification for  General Requirements for Steel Bars, Carbon and Alloy, Hot-Wrought
ASTM A31Standard Specification  for Steel Rivets and Bars for Rivets, Pressure Vessels
ASTM  A34/A34MStandard Practice for Sampling and Procurement  Testing of Magnetic Materials
ASTM A36/A36MStandard Specification for  Carbon Structural Steel
ASTM  A47/A47MStandard  Specification for Ferritic Malleable Iron Castings
ASTM  A48/A48MStandard  Specification for Gray Iron Castings
ASTM A49Standard Specification for Heat-Treated Carbon  Steel Joint Bars, Microalloyed Joint Bars, and Forged Carbon Steel Compromise  Joint Bars
发表于 2021-4-4 22:56:51 | 显示全部楼层
玩工业,要通这个,
发表于 2021-4-4 23:11:44 | 显示全部楼层
而且这些标准更新迭代特别快,说明鸟是真玩工业;汉爷有的标准漏洞百出,不过最近十几年或者二十年,很多都是equivalent ISO,这样标准制定者省事多了;
GMT+8, 2026-10-23 19:04 , Processed in 0.142169 second(s), 20 queries , Gzip On.
