查看: 2318|回复: 0
SolidWorks公有云结构构件设计平台 3D Structure Creator
发表于 2021-5-11 14:15:11 来自手机 | 显示全部楼层 |阅读模式
The new 3D Structure Creator role on the 3DEXPERIENCE® platform provides tools to automate the design of manufacturing-ready structures. Let’s take a closer look.
3D Structure Creator enables you to:
  • Freely create structure members based on any sketch entities, model edges, or curves.
  • Select structure section profiles from a library of standard types and sizes or create your own.
  • Rapidly perform trim operations at corners and endpoints to create precise, manufacturable designs.
  • Design with unique structure members by creating custom structure section profiles based on a common profile shape or user-defined 2D sketch.
  • Streamline structure design workflows with automated functionality for adding plates, gussets, and end caps.
  • Add detail to structure designs by adding cutouts to structure members.
  • Visualize an accurate representation of your final product with fully customizable graphics, realistic materials, and ambiance environments.
  • Speed design to manufacturing with automated cut lists.
  • And much more.
  • 3D Structure Creator on the 3DEXPERIENCE platform enables you to work entirely in a web browser. Secure cloud-based data management and collaboration tools powered by the platform provide the ability to view, create, or modify designs as a team from any web-enabled device.
    Creating structure members, plates, gussets, and end caps; performing corner trimming; and generating a cut list is simple and intuitive. Structure systems are automatically sorted into feature sets. Member properties can be modified at any point in the design to incorporate design feedback. And everyone in your organization has instant access to the latest design data on the platform.
    If you make simple fabricated structures, wood frames or furniture, space frames, machine bed frames, structures built from extruded aluminum, or create complex shape structures, then you may want to check out 3D Structure Creator.
GMT+8, 2026-10-23 16:02 , Processed in 0.075606 second(s), 21 queries , Gzip On.
