查看: 3449|回复: 1
SolidWorks工程报价插件:Xometry
发表于 2017-6-28 21:51:18 | 显示全部楼层 |阅读模式
Xometry is a one stop shop for manufacturing on demand and produces custom parts through a nationwide manufacturing partner network. Xometry capabilities include CNC machining, sheet metal fabrication, 3D printing and urethane casting
这个插件是可以免费使用的,只不过需要联网。Xometry项目工程总监格雷格Paulsen说“The quoting process has typically been a very labor intensive and time consuming endeavor, especially for complex orders like end-use CNC machined parts or higher volume orders, but we have removed the inefficiencies and can provide an accurate lead time and price in just seconds – all within SOLIDWORKS!” “We have been able to dramatically decrease engineering time on projects designed using the Add-In,” “By eliminating the process of tweaking and making compromise changes over the course of several days based on each manufacturer’s ability to make the parts, we are giving engineers and designers extra hours back each day to do the work they actually enjoy instead of worrying about the logistics of ordering parts.
Xometry插件的好处
1 与SolidWorks集成
2 及时得到可制造性的反馈
3 Integration with SOLIDWORKS detects threads, tolerances, surface roughness, and part material
4 Get transparent and consistent lead time estimation
5 Select from our wide range of processes including 3D Printing, Sheet Metal, and CNC Milling with over 200 materials and custom finishes
6 Easily re-quote directly in SOLIDWORKS to explore design iterations
那如何使用这个插件呢
1到这个网址下载插件xometry.com/solidworks-add-in。
2 在SolidWorks中启动这个插件,打开右侧任务窗格,联网注册一个账户
3 打开或新建一个零件文件,然后点击“Add Part to Quote”即时报价和交货时间
4 根据得到的可制造性反馈,修改设计
5 从200种备选材料中选择合适的,指定特殊的特征,比如公差 焊缝
6 选择表面粗糙度
7 添加注释和其它技术要求
8 回顾报价和订单,需要加工的话就付款(国内用户大概用不着)
http://player.youku.com/player.php/sid/XMTY5OTI1NDkzMg==/v.swf
发表于 2017-6-29 07:58:54 | 显示全部楼层
实时联网?
就问你怕不怕~
GMT+8, 2026-10-23 12:24 , Processed in 0.053348 second(s), 21 queries , Gzip On.
