查看: 2696|回复: 0
SolidWorks云打包插件3DEXPERIENCE Exchange
发表于 2022-9-30 12:02:25 | 显示全部楼层 |阅读模式
SOLIDWORKS Packages provide a new way for engineers to collaborate on designs with users outside of their organization. When sharing an assembly with an external collaborator, we typically end up with bundles of files that must be zipped and unzipped, and file suffixes like “-version2_done_withEdits_FINAL”. Importing Packages keeps assembly files all in one place, with the ability to control which files can be edited/read-only and track which files have been modified. Keep reading to learn how to import a SOLIDWORKS Package file.
The SOLIDWORKS Package File has the extension “.sldpkg”. This can be imported using one of these products:
  • SOLIDWORKS Connected (3DEXPERIENCE SOLIDWORKS)
  • Collaborative Designer for SOLIDWORKS
  • SOLIDWORKS with the free “3DEXPERIENCE Exchange” add-in
The package file contains everything needed to open the assembly which was “packaged” and will track which files have been modified.
要使用云文件打包,先启动插件
2023版的插件管理器已经内置了这一插件
在右侧的任务窗格上找到3DEXPERIENCE Exchange选项卡,单击Import Package
然后单击“Open”图标以导航到您收到的“.sldpkg”文件。导入此包将创建一个工作文件夹,默认位置为 C:用户[您的名称]文档3DEXPERIENCE_Workspace。
导入后,右侧的窗口将显示哪些文件可以编辑或设置为只读。
导入后,可以右键单击并打开右侧任务窗格的“3DEXPERIENCE Exchange”选项卡中的任何文件。您可以随时使用“刷新”按钮查看已修改文件的更新状态。
编辑完文件后,当您准备好将修改后的包返回给原始发件人时,请“导出”。从这里,您将保存一个更新的“.sldpkg”文件,该文件可以发送回您正在与之协作的 3DEXPERIENCE 用户
GMT+8, 2026-10-23 13:10 , Processed in 0.094634 second(s), 21 queries , Gzip On.
