查看: 1156|回复: 0
ChatGPT用Python做的旋转动画代码
发表于 2023-1-6 17:05:35 | 显示全部楼层 |阅读模式
ChatGPT用Python做的旋转动画代码。没有测试过。如下;
import matplotlib.pyplot as plt
import matplotlib.animation as animation
import numpy as np
# Set up the figure and axes
fig, ax = plt.subplots()
# Set up the parameters of the animation
num_frames = 360  # Number of frames in the animation
fps = 60          # Frame rate (frames per second)
# Create a function that returns the coordinates of the points to be plotted
def get_points(angle):
  x = np.cos(np.radians(angle))
  y = np.sin(np.radians(angle))
  return x, y
# Create the init function that sets up the plot
def init():
  ax.set_xlim(-1.5, 1.5)
  ax.set_ylim(-1.5, 1.5)
  line, = ax.plot([], [], "o-")  # Create the plot object
  return line,
# Create the update function that updates the plot for each frame
def update(i):
  x, y = get_points(i)  # Get the coordinates for the current frame
  line.set_data(x, y)   # Update the plot data
  return line,
# Create the animation object
anim = animation.FuncAnimation(
    fig, update, frames=num_frames, init_func=init, interval=1000/fps
# Show the animation
plt.show()
GMT+8, 2026-10-24 02:05 , Processed in 0.112398 second(s), 22 queries , Gzip On.
