查看: 1641|回复: 0
Collaborative Designer for SOLIDWORKS增强Visualize 的集成
发表于 2023-2-7 11:49:20 | 显示全部楼层 |阅读模式
The latest version of Collaborative Designer for SOLIDWORKS, R2023xGA, features enhanced integration with SOLIDWORKS Visualize and the ability to set Resolved Mode as the default.
      New – Stellar Rendering Engine Integration – easily produce photo-realistic images and impress customers.
Enjoy a consistent and enhanced visual experience through the more streamlined integration of SOLIDWORKS Visualize where you can use its new rendering engine with the 3DEXPERIENCE platform seamlessly. Now you can expect a faster, more consistent and enhanced visual experience when rendering and better yet, impress customers.
New – Automatically Optimize Resolved Mode – open assemblies faster and be more productive.
You can turn on the Resolved Mode option to have your components and assemblies always open in Resolved mode, which opens components and assemblies faster. This new option is quite helpful as it also saves you the time from having to resolve components manually for properties such as mass and weight so you can easily visualize and work with large assemblies.
If you prefer you can still set up your system to manually toggle  Resolved Mode and Lightweight Mode.
with Collaborative Designer for SOLIDWORKS, you can connect the SOLIDWORKS 3D CAD solution that you love to the cloud so you can take advantage of the data management and collaboration capabilities built into the 3DEXPERIENCE platform.
GMT+8, 2026-10-23 13:12 , Processed in 0.073806 second(s), 20 queries , Gzip On.
