查看: 1486|回复: 0
SolidWorks官方标准零件库:PartSupply
发表于 2023-2-10 11:07:29 | 显示全部楼层 |阅读模式
With 3DEXPERIENCE® Marketplace PartSupply,  PartSupply is a free online parts catalog with ready-to-use 3D parts from more than 1,700 providers.
What’s even better is that PartSupply can be directly integrated into SOLIDWORKS® desktop, cloud-connected roles like 3DEXPERIENCE SOLIDWORKS and browser-based roles like 3D Creator and more. Note: some integrations may require an add-in. With direct integration users can quickly search, find and use standard parts more quickly.
Parts on PartSupply are available for download in STEP, SOLIDWORKS, CATIA and other formats.
To find standard parts in PartSupply you can simply use the keyword search and add filters like who, what, and where to narrow it down by category, provider, country, etc.
Then once you find your part, you can drag and drop it into your design environment in SOLIDWORKS, or you can use the Open, Insert and Replace options from the PartSupply menu. The Open button opens the part as an individual part inside SOLIDWORKS. The Insert button inserts the part into the assembly inside SOLIDWORKS. And the Replace button enables you to replace the part inside your SOLIDWORKS assembly so you can use it in the assembly.
If you click on the “Find Similar” option, PartSupply will launch in another window on your desktop and all the matches or similar matches to your bolt will pop up listing the most relevant at the top. You can click on each option to learn more about the provider and specs. Then from there you have the options mentioned above drag and drop, insert, replace etc. to further investigate, validate or use/add the part.
To save the part for future use you can save it to your local folder, your PDM system, or easily store it on the 3DEXPERIENCE platform if you have access to it or you can add it to your company’s part library wherever that exists. There is an option to include your company’s custom part library directly into PartSupply as well, for an additional cost, but I think you’ll find it’s worth it.
GMT+8, 2026-10-23 13:10 , Processed in 0.107252 second(s), 20 queries , Gzip On.
