查看: 1225|回复: 0
SOLIDWORKS2025新增功能(2)
发表于 2025-3-21 09:39:57 | 显示全部楼层 |阅读模式
Support of Deformable Components – easily visualize and modify deformed components.
New functionality allows you to define and manage part behaviors by labeling them as rigid, deformable or deformed directly in SOLIDWORKS. You can access the option right from the MySession Action Bar under the Tools tab, which is applicable for saved SOLIDWORKS parts, assemblies, and virtual components. A dialog will display the current deformability status of the object for easy visualization and modification.
This is great for when you need to create multiple configurations of a part and will help you avoid making a duplicate of a part on the platform.
GMT+8, 2026-10-23 10:32 , Processed in 0.057151 second(s), 20 queries , Gzip On.
