查看: 1310|回复: 4
谷歌正式宣布 Android 安卓系统不再开源!
发表于 2025-3-27 16:42:05 | 显示全部楼层 |阅读模式
新闻自搜
发表于 2025-3-27 17:06:50 | 显示全部楼层
大胸弟,你要不会点英文,简中网会把你忽悠成瘸,聋,傻,哑。
There has been no announcement from Google stating that Android is no longer going to be open source. However, recent news indicates a shift in how Android's development process is handled. On March 26, 2025, reports emerged that Google will move Android operating system development to an internal, private process rather than continuing its fully transparent public development through the Android Open Source Project (AOSP).
Despite this change, Google has confirmed it remains committed to maintaining Android as an open-source platform. This means that while the day-to-day development will occur behind closed doors on internal branches, Google will still release the source code to AOSP after each new version is completed. This shift is intended to streamline development and reduce the fragmentation between public and private branches, but it does not signify the end of Android's open-source nature. The source code releases are expected to continue, possibly on a monthly or quarterly basis, ensuring that developers and manufacturers can still access and utilize it.
This information is based on reports from reputable tech sources like Ars Technica and Android Authority, published on March 26, 2025, which clarify that Android is not abandoning its open-source roots, contrary to what the phrasing of your question might suggest
发表于 2025-3-27 17:19:16 | 显示全部楼层
AOSP 就是 Android 开源项目的缩写(Android Open Source Project),是由 Google 主导的一个开放源代码项目,也 Android 生态系统的基础,为设备制造商、软件开发商和开源社区提供了一个强大、灵活的平台。它允许开发者(手机厂商)创建自己的基于 Android 的操作系统。
从开源性来看:AOSP 的源代码完全开放,任何人都可以下载、查看、修改和分发。
变化的是 AOSP 本身不再接受第三方代码的提交,但你依旧可以使用 AOSP 的源代码。
假设你用 AI 写了一款程序,并把代码托管到了 GitHub,说:这是免费开源的,你们来用。
在之前
如果有用户说:我来帮你添加一个新功能/修bug吧。你说:好的,你快来提交新的代码。
所有过程实时公开,包括每一个标点符号的修改。
是的,为开源项目修改标点符号,也是一个贡献。
在之后
如果有用户说:我来帮你添加一个新功能/修bug吧。你说:好的,请根据规则提交代码。
所有过程不可见,等到下一次版本发布才能看到你的贡献是否被合并。
开发模式从”实时开源”转变为”发布时开源”
相当于
Google 将把 Android 操作系统的开发过程完全转移到内部私有环境中进行。
这意味着 AOSP 的实时开发过程将不再对外
不再接受 Google 以外的开发者直接提交代码
AOSP 的开发工作将由 Google 内部团队独立完成。
怕人投毒,喂些不合适的料,就把个门。  发表于 2025-3-27 18:04
GMT+8, 2026-10-23 19:43 , Processed in 0.088820 second(s), 21 queries , Gzip On.
