查看: 1260|回复: 2
SOLIDWORKS2025新增功能(5)
发表于 2025-3-31 10:11:35 | 显示全部楼层 |阅读模式
Support for Iterations of Parts, Drawings, and Assemblies – access previous iterations.
Easily retrieve previously saved iterations of part configurations, drawings and assemblies with the Iterations command. In MySession click your part configuration and launch the command, which will essentially display a history of the part.
This is important for version control and error recovery if you’ve made a mistake and want to use a previous iteration.
发表于 2025-3-31 11:56:47 | 显示全部楼层
solidworks 的PDM在国内好难用,特别慢和卡
SOLIDWORKS PDM 使用 Microsoft SQL Server 数据库来管理文件库。  发表于 2025-3-31 12:58
GMT+8, 2026-10-23 10:33 , Processed in 0.064321 second(s), 21 queries , Gzip On.
