查看: 1289|回复: 4
SolidWorks 2026 公测开始了
发表于 2025-7-17 09:08:39 | 显示全部楼层 |阅读模式
又到了一年一度的新版solidworks公开测试的日子
Be the first to test-drive user-driven enhancements, new capabilities, and quality and performance improvements. Join now and begin exploring these key release highlights:
SOLIDWORKS Design
Collaboration and Data Management
Enhance flexibility and ease of use by enabling compatibility of multiple SOLIDWORKS versions for compliance, linking BOM data directly to PLM attributes on the 3DEXPERIENCE platform for accuracy, and managing 3D markups seamlessly within SOLIDWORKS for streamlined collaboration.
Drawings
Accelerate drawing creation by automatically generating detailed 2D drawings with proper sheet formats, intelligently arranging views and hole callouts using AI, displaying configuration data via Family Tables, and improving clarity with automatic dimension line breaks—reducing manual work and enhancing drawing accuracy and readability.
Assemblies
Boost assembly performance and efficiency with AI-powered fastener recognition and auto-mating, smarter rebuild handling that skips cosmetic-only changes, and greater control over lightweight component loading—saving time, reducing manual effort, and streamlining large assembly workflows.
SOLIDWORKS PDM
Enhance productivity, security, and administrative control with the ability to synchronize local vault views, provide user access to sub-folders without needing access to the parent folders, group unused workflows with the new Workflow archiving feature, and more.
SOLIDWORKS Simulation
Achieve precision and flexibility in your structural simulations with the ability to apply distributed mass and force to beam elements per item or as a total, define the start and end times for bolt tightening, extract detailed Pin Connector forces in random vibration simulation, and more.
在装配体中拖动零部件时,用户可能会在不知不觉中根据其视图方向将其移动很长的距离。SOLIDWORKS 现在会检测到这些较大的移动,并向用户显示警告消息。
以前,在创建边翼缘时,您可以根据现有的实体几何来定义其长度。现在,SOLIDWORKS 正在扩展此功能,通过允许您使用草图顶点来定义边线法兰的范围,从而提供更大的灵活性。这为用户在使用钣金模型构建设计意图时提供了更大的灵活性。
管理零件的多个变体是设计中的常见做法,SOLIDWORKS 长期以来一直通过配置来支持这一点。这些允许您创建单个零件文件的不同大小或版本。但是,在工程图中记录这些变化需要手动解决方法。
好消息是,SOLIDWORKS 通过在工程图中添加配置表,引入了一种新的、更有效的方法来处理此问题。这种新的表格类型经过专门设计,可以方便地显示绘图中零件或装配体的所有已配置数据。
使用展平 BOM 选项,SOLIDWORKS 现在将自动获取子装配体中存在的项目数量,并将它们汇总起来,以便在顶层装配体 BOM 中提供实例总数。这意味着您将获得整个组件所需的每个独特组件总数的清晰简洁的概述,而无需任何手动解决方法。
准备好在 SOLIDWORKS 设计中实现更逼真的视觉效果吧!很快,您将能够使用 DSPBR 着色器定义模型外观。PBR(即基于物理的渲染)将允许使用更详细、更逼真的材质。通过基于图层定义外观,颜色、反射、粗糙度和法线贴图等属性(以及更多)都有助于最终外观。此增强功能将真正提升 SOLIDWORKS 零件和装配体的视觉质量。
过去,高级选择工具并不完全适用于多实体零件。这种情况在 SOLIDWORKS 中即将发生改变。您很快就会看到对多实体零件中的选择标准的额外支持。此增强功能将提供一种更快、更高效的选择方式,让您只需点击几下即可选择相同的组件或按尺寸选择。
告别被困在操作过程中的困境!在未来的 SOLIDWORKS 版本中,您将开始看到越来越多的命令支持用于取消作的 Esc 键,从组合、壳体和相交等复杂功能开始。这将提供一种急需的方法,可以在需要时快速中断进程。
对于所有草图爱好者来说,创建正方形将变得更加容易!SOLIDWORKS 很快将提供创建等边矩形或正方形的功能,只需在绘制矩形时按住 Shift 键即可。这个看似很小的添加将自动为所有四个边添加相等的关系,无需手动应用关系,并加快了螺栓孔阵列和其他方形特征的创建。
使用“转换为钣金”功能时,SOLIDWORKS 会根据参考面识别并应用折弯、裂缝和间隙。虽然您可以定义一次应用于所有折弯的折弯半径,但如果在同一个已转换的钣金零件中需要不同的折弯半径,该怎么办?
SOLIDWORKS 即将推出,您将能够在使用“转换为钣金”功能时唯一定义每个折弯半径。这意味着,对于在转换过程中创建的所有弯曲,您将不再受限于单个弯曲半径。此增强功能还应支持放样的钣金轮廓以及转换导入的钣金几何体。
如果您曾经花时间在绘图中仔细定位注释、修订符号、几何公差、基准特征标注或表面粗糙度符号,那么您会喜欢这个即将推出的功能。SOLIDWORKS 将使您能够将这些元素和其他工程图元素直接捕捉到磁力线,而磁力线以前仅支持零件序号标注。这有助于创建清晰简洁的图纸,只需单击几下即可!
SOLIDWORKS 用户有时需要从内置 Toolbox 库外部获取标准件。令人兴奋的消息是,SOLIDWORKS研发部门正在积极致力于整合人工智能和机器学习,以仅根据其几何形状自动识别紧固件。想象一下,只需将下载的标准件模型拖放到您的装配体中,然后让它们智能地配合到位,那将是多么方便!这有望显著提高装配过程的效率,让您能够更多地专注于设计,而不是手动配接。
研发团队正在研究的另一个项目是允许用户导入复杂的网格数据、2D图像,甚至视频,并让AI智能地将它们重建为完全可编辑的参数化SOLIDWORKS模型。对于经常处理扫描数据、导入几何图形或需要将视觉信息转换为 CAD 模型的用户,这将大大简化工作流程。
在今年2月的全球用户大会上展示的有趣的潜在增强功能中,包括对达索系统的 AI 助手 AURA 及其简化产品设计初始阶段的能力。该演示强调了 AURA 如何彻底改变创建装配结构的过程。想象一下,开始一个新项目,例如电动自行车设计,并且能够简单地提示 AURA 生成基础装配结构。
AURA 的智能功能将使其能够研究指定任务的要求,并自动生成所有必要的装配、子装配和零件文件以启动项目。这意味着可以显著减少手动创建此结构层次结构的耗时初始步骤。
无论您是为基本功能工作流程而苦苦挣扎的新用户,还是寻找最佳实践建议的经验丰富的专家,AURA 都是您的首选资源。这种潜在的集成有望允许用户提出有关各种 SOLIDWORKS 功能的问题,并从用户论坛、知识库和帮助文件中提取即时的上下文相关答案。AURA 将能够提供有关最佳工作流程的建议,并指导您完成设计的不同阶段,从最初的概念化到产品的最终发布。
AURA 强调了从 CAD 模型创建引人注目的营销视觉效果的令人兴奋的未来。用户可以提供简单的提示来描述所需的结果——在所示的示例中,提示要求 AURA 生成具有 ORANGE 主题的营销图像。
然后,AURA 的强大功能将发挥作用,利用 AI 处理 CAD 几何图形,并利用用户的提示在几秒钟内生成令人惊叹的渲染图像。这意味着设置场景、应用材料和手动渲染营销视觉效果等通常耗时的过程可以显着加快。
Join the Preview Program and be among the first to experience SOLIDWORKS 2026! For more information, check out the resources on the SOLIDWORKS 2026 Preview website and the SOLIDWORKS Preview Community. Questions? Email us at preview@solidworks.com.
https://www.solidworks.com/support/preview?_gl=1*18668ja*_gcl_au*MjkyMTgwODUxLjE3NDg1NzQyMTQ.*_ga*MTMwMTU5ODMuMTY5MzcwODM4OQ..*_ga_XQJPQWHZHH*czE3NTI3MTI2NTgkbzE5NiRnMSR0MTc1MjcxMjY3NyRqNDEkbDAkaDA.*_ga_TPGKGE8GTG*czE3NTI3MTI2NjEkbzQzJGcxJHQxNzUyNzEyNjc3JGo0NCRsMCRoMA..
看出来了,达索系统也未能免俗,也要蹭上人工智能的热度。话说单机版近几年也确实没什么重大革新,不是说功能很完美了。
而是达索系统觉得单机版的永久许可证方式捞钱不够狠啊,订阅方式多好啊。月月给钱,哪天不给钱就不给用。
发表于 2025-7-17 11:12:21 | 显示全部楼层
听说沈飞用上V6了,不知真假
上海商发用的是UG  发表于 2025-7-17 20:38
而且V6也不单指CATIA,还包括DELMIA编程模块,MES模块,高级排产模块,什么5D装配模块。Simulia仿真分析,那是一个大拼盘,沾边的都叫V6  发表于 2025-7-17 11:22
没什么选择空间,国产的不中用。航空领域能用的上三维CAD,只能是CATIA,还能是Creo或NX吗。CATIA v5今年就停止更新,想增加功能那只能用3dexperience CATIA  发表于 2025-7-17 11:20
GMT+8, 2026-10-23 10:33 , Processed in 0.077063 second(s), 21 queries , Gzip On.
