查看: 9916|回复: 36
看海雕装配一个涨套有多啰嗦,你会这么做吗?应该不会
发表于 2018-8-3 16:34:40 | 显示全部楼层 |阅读模式
INSTALLATION
1. Clean shaft, bore and outside of bushing, and hub
bore of all oil, lacquer, and dirt. File away any burrs.
Insert bush on hub so that holes line up.
2. Sparingly oil thread and point of grub screws, or
thread under head of cap screws. Place screws
loosely in holes threaded in hub, indicated by ○ on
above diagram.
3. If a key is to be fitted, place it in the shaft keyway
before fitting the bush. It is essential that it is a
parallel key and side fitting only has TOP
CLEARANCE.
4. Clean shaft and fit hub to shaft as one unit and
locate in position desired, remembering that bush
will nip the shaft first and then hub will be slightly
drawn to the bush.
5. Using a hexagon wrench, tighten screws gradually
and alternately to torque shown in table.
6. Hammer against large end of bush using block or
sleeve to prevent damage. (Do not Hit Bushing
Directly With Hammer). (This will ensure that the
bush is seated squarely in the bore.) Screws will
now turn a little more. Repeat this alternate
hammering and screw tightening once or twice to
achieve maximum grip on the shaft.
7. Recheck screw torque after initial run-in, and
periodically thereafter. Repeat steps 5 and 6 if
loose.
8. Fill all unoccupied holes with grease. Where
bushing is used with lubricated products such as
chain, gear or grid couplings, be sure to seal all
pathways (where lubricant could leak) with RTV or
similar material.
* If two bushings are used on the same component
and shaft, then fully tighten one bushing before
working on the other.
其后面还有一个力矩表,哪个螺栓拧到多大力矩,哈哈,
  • · 学习|主题: 113, 订阅: 27
发表于 2018-8-3 21:14:40 | 显示全部楼层
1.清洗轴、孔、衬套外部,以及毂孔上的油、漆、杂质。
锉掉毛刺。衬套插入毂孔上便于孔对齐。
2.涂少量油到螺纹上和顶丝顶尖上,或螺钉螺帽以下
螺丝上。如上图所示,将螺钉稍稍旋入毂上的螺纹孔里。
3.如果是键配合,在放置衬套前将键放入轴上键槽里。
平行键配合时,只允许键的顶部有间隙,这一点非常重要。
4.清洗轴后,将毂配合轴上使其成为一个单元并定位在
想要的位置,记住先将衬套卡在轴上,然后轻轻动毂进入衬套。
5.使用六角扳手将螺钉缓慢并交叉拧到图表中的力矩。
6.用锤子敲击时,使用套筒或垫块在衬套的大头以免损伤衬套。
(不允许使用锤子直接敲击衬套)(这样确保衬套紧贴着孔)
螺钉可以多旋转一点。重复交叉敲击。螺钉拧紧一到两次以使衬套
抱紧轴。
7.在初次宁今后,再次检查螺钉的扭矩,以后定期检查。
如果发现松了,重复5、6步骤。
8.将闲置的孔中注入油脂。当衬套用在需要润滑的产品上时,
如链条、齿轮、蛇型联轴器,确保所有通道用RTV或类似材料
密封住(防止润滑剂泄露)。
当两个衬套用在同一个零件或轴上,先完全拧紧一个再安装下一个。
回复 支持 6 反对 0
发表于 2018-8-3 16:54:53 | 显示全部楼层
我还真是这么装涨套。
大侠能翻译下不  发表于 2018-8-3 18:43
难道就我不信吗  发表于 2018-8-3 17:17
7万
发表于 2018-8-3 17:03:07 | 显示全部楼层
不仅是介绍详细。干活的人也麻烦。
福特现场施工的工程师。什么都要齐全。不仅要求自己这样。别的人也要跟他这样。否则就不干活。
要吃小龙虾。喝2瓶啤酒。喝完啤酒。要抽雪茄。这个时候就不讲究了。拿着刀直接割。哈哈
工欲善其事,国内除了一些老国企,在工具辅具方面没有这方面概念,这些不起眼的东西,这会严重影响产品质量,这种装备齐全的工作方式是梦寐...  发表于 2018-8-5 10:23
发表于 2018-8-3 17:20:27 | 显示全部楼层
请老外过来干活,一天1万前两天,就是打磨,去毛刺,倒角,一个一个零件过,第三天开始在下面试装,
你要看到他为了配一个垫片而搞了半天,会感叹,
中国人,是钱的问题吗?
第一是态度,第二,是不懂技术细节,
是原则问题,我们常常遇到,领导让你对付,对付的后果你知道,所以你不做,如果你不做,别人会做,为什么这样,什么问题最后都是政治导向  发表于 2018-8-5 10:28
国人这个干活,一定会被嘲笑的,没有这个基因,认为是浪费时间,磨洋工,什么难听的都有。  发表于 2018-8-4 08:53
不仅仅是懒的问题,真的,其实是不懂  发表于 2018-8-3 20:46
就是懒  发表于 2018-8-3 20:20
发表于 2018-8-3 17:21:42 | 显示全部楼层
你会这么做吗?当然不会
发表于 2018-8-3 17:26:25 | 显示全部楼层
没见过海雕工程师。上家公司见过德国佬和意大利佬,区别很大。德国佬,工具箱打开,工具布放到操作台,把每个步骤的工具摆好,严格按照步骤,精细严谨,用过的工具整齐的放回工具布上,我帮忙,红毛还怕我修不好,不乐意。意大利佬,跟他一起拆装压缩机,精细度感觉还不如我,中间看我拆装很符合他们的要求,居然就自己在旁边休息起来了。
哈哈,俺在现场做助手就是德国人那样滴,以至于做家务煮饭时细节多特别慢,职业病了,哈哈  发表于 2018-8-3 21:58
层主应该听说过意呆利的二战轶事  发表于 2018-8-3 20:24
画加工件、钣金件什么的有规律,建装配体也有规律。很复杂也不会有过定义什么的。我自己经常就乱哄哄了,有时还画的时候就过定义,再删除定...  发表于 2018-8-3 18:56
什么套路,讲讲,学习一下  发表于 2018-8-3 18:40
德国佬认真啊,画个破图都一板一眼。sw画图都有一个固定套路。  发表于 2018-8-3 17:58
发表于 2018-8-3 18:42:08 | 显示全部楼层
没玩过涨套啊
俺见过的都是刚性联轴器,
原来俺见的都是低端货
发表于 2018-8-3 20:21:04 | 显示全部楼层
说起涨套
记起以前在公明镇打工的时候,有个木器加工厂的设备上有个涨套
他们把螺丝下光也下不下来
其实就是一把起子打进缺口,轻轻松松拿下来
发表于 2018-8-3 20:21:42 | 显示全部楼层
这个安装指导有几个地方比国内胀套厂商给的说明要详细,比如拧紧过程与用锤子敲正的过程交替进行,以及所有螺钉力矩到位后还要多次检查松懈情况,这个在看过的国内说明书都没看见过,国内一般就是1/3对对拧紧,1/2紧,全力矩紧后再全力矩检查一遍。
而用橡胶堵润滑脂这应该是特定工况?不是所有的胀套都有这步吧。
一般国内说明书还会说一点,用不带二硫化钼的一薄层润滑油涂在轴和胀套结合面上,不含二硫化钼类的成分应该是为了工作传递扭矩时不降低摩擦系数,而涂这薄层本身的目的我的理解一是为了胀套内圈抱紧轴过程中能均匀接触,二可能是为拆卸考虑,轴、套结合面为了增大摩擦系数粗糙度一般取比较小,长时间胀紧连接会类似过盈连接的粘结从而使拆卸力远大于安装拧紧力,涂这一薄层会有改善?这个就是自己想的了,没有理论根据,8爷给出的安装过程没有这一步,应该也是视具体情况而来了。
键槽不许两侧有间隙,这个书上有,也实际体会过了,如果是冲击工况,短期啃键概率还是大的。最后还没看过胀套用键槽的,印象中一般是锥套带键槽,不确定,是自己没见过,或是哪句话没理解正确。
发表于 2018-8-3 20:24:30 | 显示全部楼层
不知道海雕怎样下套?
GMT+8, 2026-10-24 00:06 , Processed in 0.108612 second(s), 25 queries , Gzip On.
